March 2025 - Free ASCE Papers
  • 1.  March 2025 - Free ASCE Papers
    Posted 03-05-2025 12:57 PM
    ASCE provides a healthy number of free research papers each month. The following is a list of free publications content for the month of March 2025. These papers are also featured on the following page while they are open: https://ascelibrary.org/editors_choice_papers
    (Note: When you click on the link you will be leaving Collaborate.asce.org and directed to ASCELIBRARY.org where you must re-enter your ASCE login credentials to access the free content. The login button is in the upper-right corner).
    I'll be sharing these papers each month to encourage discussion on some of these topics. I'll also be tagging these posts as "ASCE Papers" for you to easily access in the future. Please feel free to comment on other areas where you might like to see additional research as well!
    Editor's Choice Collection
    For each issue of the journal, the Chief Editor may select a paper to be featured on the journal homepage in the ASCE Library. The paper is available for free to registered Library users for 1 to 4 months, depending on how frequently the journal is published. Below is the list of current Editor's Choice selections.
    Journal
    Title
    Journal of Aerospace Engineering
    Investigation of the Dynamic Properties of Viscoelastic Dampers with Three-Chain Micromolecular Configurations and Tube Constraint Effects
    Journal of Bridge Engineering
    Effect of Climate Change on Thermal Loads in Concrete Box Girders
    Journal of Construction Engineering and Management
    Gap Analysis of Digitalization Levels in Construction and Manufacturing: A Comparative Study of Construction 4.0 and Industry 4.0
    Journal of Computing in Civil Engineering
    LiDAR-Simulated Multimodal and Self-Supervised Contrastive Digital Twin Approach for Probabilistic Point Cloud Generation of Rail Fasteners
    Journal of Cold Regions Engineering
    Influence of the Principal Stress Rotation on the Stiffness and Damping Ratio of Frozen Clay under Cyclic Loading
    Journal of Environmental Engineering
    Integration of Climate Impact Assessment in the Total Maximum Daily Load Models
    International Journal of Geomechanics
    Failure Mode Characteristic of Rocks Containing a Weak Interlayer with Different Thickness and Dip Angles Based on Discrete-Element Method
    Journal of Geotechnical & Geoenvironmental Engineering
    Distributed Fiber-Optic Monitoring of Free-Field Soil Response under Normal Faulting: Full-Scale Experiment and Analytical Solution
    Journal of Infrastructure Systems
    Pavement Condition Prediction for Communities: A Low-Cost, Ubiquitous, and Network-Wide Approach
    Journal of Management in Engineering
    Developing Data Requirements for City-Level Digital Twins: Stakeholder Perspective
    Journal of Materials in Civil Engineering
    Correlating the Fatigue Response of Asphalt Binders and Mixtures Prepared Using Warm-Mix Asphalt Technologies
    Journal of Transportation Engineering, Part B: Pavements
    Drones for Road Condition Monitoring: Applications and Benefits
    ASCE-ASME Journal of Risk and Uncertainty in Engineering Systems, Part A: Civil Engineering
    Variability in Geostructural Performance Predictions
    Journal of Structural Engineering
    Seismic Performance of Steel Frame Structures with Novel Self-Centering Beams: Shaking-Table Tests and Numerical Analysis
    Journal of Transportation Engineering, Part A: Systems
    Three-Dimensional Object Detection and High-Resolution Traffic Parameter Extraction Using Low-Resolution LiDAR Data
    Journal of Urban Planning and Development
    Multifunctional Role of Land-Use Planning in Peri-Urban and Urban Agricultural Drylands: The Mediating Effect of Urbanization Level
    Journal of Water Resources Planning and Management
    Water Pressure Prediction in a Water Supply Network Using the Informer Framework
    Journal of Waterway, Port, Coastal, and Ocean Engineering
    Hydraulic Performance of Low-Crested and Emergent Breakwaters with Ecologically Designed Armor Units
    Tirza Austin
    Senior Manager, Online Community
    American Society of Civil Engineers
    1801 Alexander Bell Drive
    Reston, VA 20191
