Hi Jeanne,
Thanks for your opinion.
Given the efforts and knowledge you gained becoming certified and keeping it current,
consider how you might adapt elements of it to the work within your org.
i.e., Process Mgmt., Quality Mgmt., Risk Mgmt., etc.
Adapting such work to the particulars of your work will add value to your customers as well as your colleagues and yourself.
And perhaps once your mgmt sees the results, they will see the wisdom in supporting your PMP.
"Engineering knowledge is necessary, but not sufficient to assure each project is delighted by your customer."
-w. m. hayden jr.
Stay Healthy!
Cheers,
Bill
William M. Hayden Jr., Ph.D., P.E., CMQ/OE, F.ASCE
Buffalo, N.Y.
"It is never too late to be what you might have been." -- George Eliot 1819 - 1880
Sent: 01-18-2021 02:10 PM
Subject: How PMP will support the Professional Career of Civil Engineers
To answer the original question, "How does a PMP certification support the professional career of Civil-Structural engineer in the technical field?", it doesn't at all if your intent is to stay in a technical rather than management career path. If you do intend to become or continue as a project manager AND you work for an A/E consulting firm, then the PMP certification is at least beneficial and may be required in some cases. I am in the water sector, but that was my experience when working in consulting. Now that I am employed by a utility that does not have a project management culture, my PMP is almost worthless and the continuing education can be hard to come by.
Jeanne L. Finger, PE, PMP, M. ASCE
Spokane, WA
Sent: 01-17-2021 09:26 PM
Thanks to all for your valuable thoughts, advise and suggestions. This will certainly help.
Thanks again.
Munish Dhawan M.ASCE
Lead Civil Structural Engineer
Fluor Daniel India Private Limited
Gurgram
Sent: 01-14-2021 05:50 PM
Reflections For Munish & Fabricio to Consider:
* Munish
1 of 2: When searching the "Job Ads" for various engineering work a few years ago, many would state in their ad "PMP Preferred."
These days, most all such ads for project managers and certain engineering work state "PMP Required."
2 of 2: The very discipline required to successfully pass the PMP exam exposes you to new ways of thinking about familiar project practices.
* Fabricio:
Fabricio, placing the word predictive in front of an expression means you have data that supports your argument that a specific management process outcome can be predicted. Absent such data, one might say "Anticipated Management Process."
I do like your use of "Tailoring" to plan, design, and apply the results of your own application of so-called PMI best practices. To be clear, PMI-Best Practices are not to be considered as "Constants." The only constant in project work is change!
Stay Healthy!
Cheers,
Bill
Buffalo, N.Y.
Sent: 01-11-2021 10:10 AM
I have always thought it beneficial to built-environment projects to have engineers managing them. The PMI certifications are helpful in solidifying the practice of project management as a profession rather than a role in the minds of PMs, as well as widening their skill set. The construction industry, therefore, can benefit from not only having engineers managing projects but having them trained and up to date in PM best practices.
Richard McGrath A.M.ASCE
Structural Engineer
Airdrie AB
