Discussion: View Thread
ASCE Papers - Free June Papers 2023
  • 1.  ASCE Papers - Free June Papers 2023
    Posted 06-02-2023 11:12 AM
    ASCE provides a healthy number of free research papers each month. The following is a list of free publications content for the month of June 2023. These papers are also featured on the following page while they are open: https://ascelibrary.org/editors_choice_papers
    (Note: When you click on the link you will be leaving Collaborate.asce.org and directed to ASCELIBRARY.org where you must re-enter your ASCE login credentials to access the free content. The login button is in the upper-right corner).
    I'll be sharing these papers each month to encourage discussion on some of these topics. I'll also be tagging these posts as "ASCE Papers" for you to easily access in the future. Please feel free to comment on other areas where you might like to see additional research as well!
    Journal
    Title
    Open
    Close
    DOI
    Journal of Architectural Engineering
    Wind-Induced Vibration and Wind-Driven Rain Performance of a Full-Scale Single-Skin Facade Unit with Vertical Protrusions
    6/1/2023
    8/31/2023
    https://doi.org/10.1061/JAEIED.AEENG-1393
    Journal of Bridge Engineering
    Modelling the Nonlinear Behavior of the Pot Bearings of Railway Bridge KW51
    6/1/2023
    6/30/2023
    https://doi.org/10.1061/JBENF2.BEENG-6144
    Journal of Composites for Construction
    Performance-Based Environmental Assessment of FRP-Confined Concrete Stub Columns: Investigation on FRP Types
    6/1/2023
    7/31/2023
    https://doi.org/10.1061/JCCOF2.CCENG-4083
    Journal of Performance of Constructed Facilities
    An Eddy Current Testing Method Based on Magnetic Induction Intensity for Detecting Cracks in Steel Bridge Decks
    6/1/2023
    7/31/2023
    https://doi.org/10.1061/JPCFEV.CFENG-4235
    Journal of Construction Engineering and Management
    Systematic Review of the Literature on Construction Productivity
    6/1/2023
    6/30/2023
    https://doi.org/10.1061/JCEMD4.COENG-13045
    Journal of Cold Regions Engineering
    Expanding Liquid Application Rate Guidance with Field Data and Practitioner Experience
    6/1/2023
    8/31/2023
    https://doi.org/10.1061/JCRGEI.CRENG-673
    Journal of Environmental Engineering
    Rehabilitation Technologies to Abate Infiltration in Sanitary Sewers
    6/1/2023
    6/30/2023
    https://doi.org/10.1061/JOEEDU.EEENG-7177
    Journal of Energy Engineering
    Multiobjective Optimization of a Parallel Liquid Cooling Thermal Management System for Prismatic Batteries
    6/1/2023
    8/31/2023
    https://doi.org/10.1061/JLEED9.EYENG-4793
    Journal of Hydraulic Engineering
    Wave Boundary Layer over a Rough Bottom at Moderate Reynolds Numbers
    6/1/2023
    6/30/2023
    https://doi.org/10.1061/JHEND8.HYENG-13297
    Journal of Irrigation and Drainage Engineering
    Computational Simulation of the Flow Induced by Water Leaks in Pipes
    6/1/2023
    6/30/2023
    https://doi.org/10.1061/JIDEDH.IRENG-10089
    Journal of Infrastructure Systems
    Robust Design of Electric Charging Infrastructure Locations under Travel Demand Uncertainty and Driving Range Heterogeneity
    6/1/2023
    8/31/2023
    https://doi.org/10.1061/JITSE4.ISENG-2191
    Journal of Materials in Civil Engineering
    Bioconcrete: Harnessing the Endogenous Microbiota of Reinforced Concrete for Crack Remediation
    6/1/2023
    6/30/2023
    https://doi.org/10.1061/JMCEE7.MTENG-14920
    ASCE-ASME Journal of Risk and Uncertainty in Engineering Systems, Part A: Civil Engineering
    What Geotechnical Engineers Want to Know about Reliability
    6/1/2023
    8/31/2023
    https://doi.org/10.1061/AJRUA6.RUENG-1002
    Journal of Structural Engineering
    Fracture Mechanics–Based Fragility Assessment of Pre-Northridge Welded Column Splices
    6/1/2023
    6/30/2023
    https://doi.org/10.1061/JSENDH.STENG-11749
    Journal of Transportation Engineering, Part A: Systems
    The Economic Value of Reserve Capacity Considering the Reliability and Robustness of a Rail Transit Network
    6/1/2023
    6/30/2023
    https://doi.org/10.1061/JTEPBS.TEENG-7691
    Journal of Urban Planning and Development
    Land Administration in the Territorial Development System of the Regions: Theoretical Issues and Evaluation Methodology
    6/1/2023
    8/31/2023
    https://doi.org/10.1061/JUPDDM.UPENG-3682
    Journal of Water Resources Planning and Management
    Location and Design of Flow Control Structures Differentially Influence Salinity Patterns in Small Artificial Drainage Systems
    6/1/2023
    6/30/2023
    https://doi.org/10.1061/JWRMD5.WRENG-5840
    Tirza Austin
    Senior Manager, Online Community
    American Society of Civil Engineers
    1801 Alexander Bell Drive
    Reston, VA 20191
