ASCE Book Club - Free Papers June 2025
  • 1.  ASCE Book Club - Free Papers June 2025
    Posted 11 days ago
    ASCE provides a healthy number of free research papers each month. The following is a list of free publications content for the month of June 2025. These papers are also featured on the following page while they are open: https://ascelibrary.org/editors_choice_papers
    (Note: When you click on the link you will be leaving Collaborate.asce.org and directed to ASCELIBRARY.org where you must re-enter your ASCE login credentials to access the free content. The login button is in the upper-right corner).
    I'll be sharing these papers each month to encourage discussion on some of these topics. I'll also be tagging these posts as "ASCE Papers" for you to easily access in the future. Please feel free to comment on other areas where you might like to see additional research as well!
    Editor's Choice Collection
    For each issue of the journal, the Chief Editor may select a paper to be featured on the journal homepage in the ASCE Library. The paper is available for free to registered Library users for 1 to 4 months, depending on how frequently the journal is published. Below is the list of current Editor's Choice selections.
    Institute
    Journal
    Title
    DOI
    Open
    Close
    SEI
    Journal of Bridge Engineering
    Design Considerations for Composite Steel Bridges Using 29-mm Diameter Shear Studs and Partial-Depth Precast Concrete Panels: A Finite-Element Study
    https://doi.org/10.1061/JBENF2.BEENG-7145
    6/1/2025
    6/30/2025
    CI
    Journal of Composites for Construction
    Shear and Flexural Strengthening of Glued-Laminated Timber Beams Using Externally Bonded Fiber-Reinforced Polymer Sheets
    https://doi.org/10.1061/JCCOF2.CCENG-5074
    6/1/2025
    7/31/2025
    Journal of Performance of Constructed Facilities
    Reporting on Age-Based Building Inspections Programs in South Florida
    https://doi.org/10.1061/JPCFEV.CFENG-4875
    6/1/2025
    7/31/2025
    CI
    Journal of Construction Engineering and Management
    Enhancing the Manufacturing Process in Light-Gauge Steel Off-Site Construction Using Semiautomation
    https://doi.org/10.1061/JCEMD4.COENG-15335
    6/1/2025
    6/30/2025
    Journal of Cold Regions Engineering
    Lateral Performance of Bridge Pile Foundations in Seasonally Frozen Soils Considering Ground Scour Effect
    https://doi.org/10.1061/JCRGEI.CRENG-891
    6/1/2025
    8/31/2025
    EWRI
    Journal of Environmental Engineering
    Hydrothermal Chemical Modification of Biochar for Improving Cd and Pb Adsorption: Performance and Mechanism
    https://doi.org/10.1061/JOEEDU.EEENG-8059
    6/1/2025
    6/30/2025
    GI
    International Journal of Geomechanics
    Nonlinear Consolidation Analysis of Stone Column Composite Foundations Considering Radial and Vertical Flows within the Stone Column and the Variation of Well Resistances
    https://doi.org/10.1061/IJGNAI.GMENG-11059
    6/1/2025
    6/30/2025
    GI
    Journal of Geotechnical & Geoenvironmental Engineering
    Tailings Dam Performance Monitoring by Combining Coda Wave Interferometry with Distributed Acoustic Sensing
    https://doi.org/10.1061/JGGEFK.GTENG-13066
    6/1/2025
    6/30/2025
    EWRI
    Journal of Hydrologic Engineering
    General Infiltration Law for Structured Soils from the Porous Media Momentum Equation and Its Simplification for Horton's Law
    https://doi.org/10.1061/JHYEFF.HEENG-6332
    6/1/2025
    7/31/2025
    EWRI
    Journal of Irrigation and Drainage Engineering
    Overflow of Dual Parapet Walls on Dam Crests
    https://doi.org/10.1061/JIDEDH.IRENG-10549
    6/1/2025
    7/31/2025
    TDI
    Journal of Infrastructure Systems
    Evaluating the Resilience of Interdependent Infrastructure Systems with a Focus on Community Livability
    https://doi.org/10.1061/JITSE4.ISENG-2658
    6/1/2025
    8/31/2025
    CI
    Journal of Materials in Civil Engineering
    Gas Permeability and Pore Structure Analysis of an Ultrahigh-Durability Oil Well Cement Mortar Plug Using Micro-CT Scans
    https://doi.org/10.1061/JMCEE7.MTENG-19869
    6/1/2025
    6/30/2025
    ASCE-ASME Journal of Risk and Uncertainty in Engineering Systems, Part A: Civil Engineering
    Parallel Multifidelity Design of Experiment Strategy Considering Low-Fidelity Simulation Feasibility
    https://doi.org/10.1061/AJRUA6.RUENG-1497
    6/1/2025
    8/31/2025
    SEI
    Journal of Structural Engineering
    Beyond Development: Challenges in Deploying Machine-Learning Models for Structural Engineering Applications
    https://doi.org/10.1061/JSENDH.STENG-13301
    6/1/2025
    6/30/2025
    TDI
    Journal of Transportation Engineering, Part A: Systems
    Planning and Design of an Integrated Railway–Highway Infrastructure: A Review
    https://doi.org/10.1061/JTEPBS.TEENG-8329
    6/1/2025
    6/30/2025
    TDI
    Journal of Urban Planning and Development
    Application of Machine Learning Algorithms to Predict Urban Expansion
    https://doi.org/10.1061/JUPDDM.UPENG-5466
    6/1/2025
    8/31/2025
    EWRI
    Journal of Water Resources Planning and Management
    Conceptual Framework for Leak Development in Water Distribution Systems
    https://doi.org/10.1061/JWRMD5.WRENG-6673
    6/1/2025
    6/30/2025
    Tirza Austin
    Senior Manager, Online Community
    American Society of Civil Engineers
    1801 Alexander Bell Drive
    Reston, VA 20191
