Professionally, I typically felt unheard in those emergency or urgent situations or the pre-urgent situations with co-workers (and management) with whom I did not normally work with. I believe entirely due to different areas of expertise relative to the design, analysis or construction process. It is great when your supervisor or group lead is the barrier between you and others outside the group or department; it is extremely challenging when they are not advocating for you.
"How soon can you get this done?"The funniest situations (or other f-word being frustrating) being the "How soon can you get this done?". You provide the most optimistic (all things go perfect) and the most pessimistic (chasing stresses, on the fly revisions by others, etc.). They come back an hour later with a counter that is sooner than the most optimistic. [Note: I always question why they even asked!] Then I have to provide the justification for extending the ECD and explanation for missing the deadline. X number of load cases. Need to time to review and actually examine the results.
"Repeat and repeat often" Once I spent months in prep meetings stating "
For the record, I'm not a mechanical engineer.". If you have ever had a mechanical designer create a model, you know that they model down to the screw. The project manager (that selected me to perform the analysis) refused to accept my estimation of hours due to his understanding that I could simply transfer a model and run analyses. I explained that structure and mechanical systems are different.
The language used was foreign to me. I was unsure of the guidance, specifications and code checks. No matter my explanation as to the differences and my unfamiliarity, the PM repeatedly stated "
Oh, you can do it!". [Note: Did not need a pep talk. I needed them to understand that building, working with & animating models was different from what is analyzed, how elements are analyzed and the best tools for analysis.]
Finally, as we approach the date for me to start, the mechanical designer throws up this complex solid model that includes moving pieces, rolling stuff, and all the elements that make the model a work of art. I state "
For the record, I'm not a mechanical engineer. As a structural engineer, I would throw out 98.5% of that model to create the model I would need for my typical analysis." To which, the mechanical designer agreed. The PM, I just thought you simply transferred and used his model.
I do not know of too many projects in design where being quiet is an option when it comes to safety and public welfare, co-workers or supporting equipment. I have sat quietly in meetings when new to a project. I will ask a team member during the meeting, meeting break or after. Until I know otherwise, I believe there are subject-matter-experts present or supporting.
James Williams P.E., M.ASCE
Principal/Owner
Yorktown, VA
