Thank you for your interest.
There are at least three loads for which performance based design is being examined in detail. Seismic is perhaps the most established, with wind and now fire response following in step. But it really isn't the load source or site location that determines the merits of design according to performance. Performance based design could be used legitimately for any structure for all loads, with the benefit being 1) a better understanding of the actual performance expectations, 2) more flexibility to address multiple and potentially competing performance goals, 3) greater efficiency in the selection and use of materials, and 4) potentially even lower total cost in most cases. These benefits and others need to be demonstrated through study and practice, and such efforts are underway.
That said, it is not obvious that performance based design would be the best approach for all structures. I can imagine that design phases for time-critical routine projects could be shorter following conventional design than for performance based design. In fact, the profession is nearing a state of automated design for such structures. Performance based design might also entail peer reviews and more intensive code compliance assessments than are needed now for conventional design. At the same time, the overall savings for routine structures might not justify the pursuit. But it depends on what you value.
I expect that performance based design will be used first for structures that show clear promise for benefit, and these (and large bridges) might be the ones you list. However, as the construction industry's familiarity with the process increases and building codes become more progressive, we are likely to witness the threshold for structures that would receive net benefit lowering.
On your second question, we are pursuing performance based design for seismic and fire exposures. I anticipate that the frequency with which we engage in performance based design will increase substantially in the next few years.
Donald Dusenberry F.SEI, F.ASCE
Simpson Gumpertz & Heger Inc.
Waltham MA
(781) 907-9237
dodusenberry@...------------------------------
