When in doubt, be conservative. . . Unless being conservative (piled onto more conservative assumptions) makes for an astronimcal design. Having said that and looking at the commentary, it would seem you need to consider unbalanced on the 25°(ALT+176) side because it is between flat and 30° and suceptible to drift. You would not need to consider it on the 45° side per the code.
Nathan Smith P.E., M.ASCE
Engineer
Greensboro NC
