Any time I've used a turnbuckle it was in a tension only member, so I understand why there is no or limited published data on compression. I was always taught that "you can't push a rope", and as these devices are almost exclusively used for long, slender members it would be interesting to know the type of applications whereby you need to have a turnbuckle in compression.
David Kennicutt, PE (NY), M.ASCE
