Ryan,
Check out the following Youtube video from an Engineer for RISA 3d. It was very helpful for Non-Building Structures and Wind loading.
I use ASCE 7-10 ASD and I use the trussed towers section to determine the wind loads. I calculate the wind pressure every 10 feet along the height of the tower (or whatever the tower section heights are). The bottom section is seeing the wind pressure calculated at 10' height and then the section from 10' to 20' is seeing the wind pressure calculated at 20' height etc. rather than calculating the wind pressure at 150' and applying it to the entire 150' of the tower. This is more work for sure but results in an overall smaller load.
I use the 4 load cases in Figure 27.4-8.
Case 1 is full wind pressure acting on all projected surfaces normal to each axis.
Case 2 is 75% of the wind pressure acting on each axis with a torsional load.
Case 3 is 75% of the wind pressure acting on all axis simultaneously
Case 4 is same 75% of case 2 acting simultaneously on all axis
Use the load combinations in 2.4 if you are designing with ASD. You will see that the wind load has a 0.6 multiplier.
You may also want to look at Ice loading as well in chapter 10
Wind Loading on Non-Building Structures in RISA
| YouTube |
remove preview |
| Wind Loading on Non-Building Structures in RISA |
| This recorded webinar shows you how to calculate and apply wind loading for a non-building or industrial type structure in RISA-3D. Examples like towers, tanks and open structures are shown. This is part 2 of a 3 part series of webinars. |
| View this on YouTube > |
Randall Lehman P.E., M.ASCE
Honeyville Metal Inc.
Topeka IN
