REMUNERATION FOR ENGINEERING SERVICE: Terms & Conditions for residential structural engineering services?
Considering the work scope, which is structural integrity test and inspection of foundation, wall cracks, and enumerating on the failure mode and sustainability
Foundation is within the soil ground, but if there is settlement it can be pronounced in the substructures, through vertical downward displacement of the structure. When the displacement becomes excessive, it could affect the functionality of the building.
Wall Cracks: Cracks in non-load bearing walls can easily be amended than for load bearing walls.
Structural Integrity Tests can be performed, if the observed characteristic is critical and could affect the service performance. The common integrity tests for existing structures are non destructive, to determine the stress limit, strain and existing deformation on the structure, and to suggest methods of rehabilitation.
The remunerations will be determined from the magnitude of service, and cost per unit of the activities.
Olusegun Afolabi R.Eng
Lagos
234803 4248600
