  • 1.  Suggestions Over Concrete Shooting?
    Posted 10-12-2018 10:04 AM
    Edited by Tirza Austin 10-12-2018 10:03 AM
    Hi all,
    Pumping concrete to high rise structures require wetter mix that may result even up-to 7" slump. Is increasing in slump results
    aggregate segregation that might cause serious loss of strength in concrete?
    Sayed Maqsood S.M.ASCE
    Oakland CA
    (510)395-4361
  • 2.  RE: Suggestions Over Concrete Shooting?
    Best Answer
    Posted 10-14-2018 09:12 AM
    Edited by Sayed Maqsood 10-30-2018 08:47 AM
    The proper mix design can be readily achieved without sacrificing desired properties.  The water cement ratio can be maintained by using a high range water reducing agent in order to achieve the desired pumpability (I.e. slump).  Proper selection of aggregate and sand is also important for good performance when using a pump. A reputable ready mix concrete supplier can provide mix designs that have been successful used in the past.
    Gregory Shafer P.E., S.E., M.ASCE
    BRidge Technical Manager
