Good points. The geometry of the strut cross-sections is an important factor.
When I built ferrocement boats in the 1970's we made various struts by rolling wire mesh layers into a rough circular cross-section, then inflating to a very loose fit sausage balloons that had been slipped up in the annulus of the mesh section before the struts were set in place between end supports. It was tricky to lay-up staggered layers of mesh as the mortar was manually applied, especially at the ends of the struts and the adjoining supports. Typical length (1.5-2 meters) 80 to 100 mm ID 4-layer mesh struts had 20 to 25 mm wall thicknesses, based on some random drill holes, with the struts flaring a bit and being solid within 100 to 150 mm of the end supports. Our longest struts were about 3 meters, with wall thicknesses of nominal 30 mm for 5-6 layers of mesh. And, yes, when we did pop an occasional balloon, we just pressed on with extra mortar at that section.
They were very strong. Never heard of any strut cracking. Of course, these were real struts, not imaginary ACI struts.
Robert Bullard P.E., M.ASCE
President
Ahimsa Technic Inc
Ponce Inlet FL
Sent: 05-08-2017 09:30
Subject: STRUT-AND-TIE ACI 318 Model for Thin Concrete Shells
I think we would need to see some validation testing, since the struts are three-dimensional. The expected failure mode in compression is tension across a strut - as with inclined shear cracks in beams. In a relatively thin member, there might be insufficient confinement of the compression struts for them to behave as expected using a traditional model. If the section has reinforcement across the narrow aspect, with adequate confinement, it might behave as expected. Otherwise, it seems likely that the strut could fail prematurely. Santiago Pujol at Purdue has been looking at thin wall sections for quite some time and may have some insight into this.
John Turner P.E., M.ASCE
Wiss, Janney, Elstner Associates, Inc.
Irving TX
