Mohammad,
Great question. The answer varies greatly depending on what field within structural engineering you are planning to work. I have work in Industrial, Residential, and now bridges and have used a combination of multiple software. I would say, in terms of finite element analysis, RISA seems to be very popular for steel design. Other great options I have seen are SAP2000 and ETABS. Currently, I do a lot of work with MIDAS Civil. No matter what software you end up using the concepts and way you create your model is exactly the same, they all use the same back end calculation method (via stiffness matrices). I would suggest you learn at least one of them (probably RISA 2D or 3D) and you can apply that knowledge to any other program. The only difference you will see is some additional (or lack of) features that could be quickly learned.
As per other software, again it varies a lot depending on what you are working on. I have used Tekla Tedds for "hand calculation", proprietary manufacturer software (HILTI PROFIS, Simpson Anchor, etc..), RISA Connection and Foundation (an extension of RISA 3D), ShapeBuider, ConcreteSection, etc..
For other "simpler" calculations we use a lot of excel spreadsheets and Mathcad sheets (really good program to learn).
I would recommend you tackle a FEM program and that knowledge will transfer to any other program with minor changes. Most other calculations are done either by hand, excel spreadsheets, or other very intuitive software in my experience.
Let me know if you have any other questions.
Luis Duque EIT, A.M.ASCE
Structural Engineer
Broomfield CO
luis.duque674@...------------------------------
