Collaborate Home
My Profile
Browse
Discussion Posts
Glossary
Library Entries
Member Home (Admin)
2.1K
36.4K
Back to discussions
Expand all
Collapse all
sort by most recent
sort by thread
Steel structure
Abu Ahmed
03-13-2020 10:00 AM
Hi, I am about to build a concrete footing for steel elevator but I have to excavate 1.5 m under the ...
Dennis Young
03-14-2020 09:17 AM
If the steel framing for the elevator is set on the footing with the top of footing below grade, and ...
Stacey Morris
03-14-2020 09:17 AM
Look at the building architect's plans. ------------------------------ Stacey Morris P.E., M.ASCE ETI ...
Darin Gatti
03-14-2020 11:49 AM
As Mr Young point out, burying steel is generally not a good idea and the protection he suggested works ...
Qingsong Shi
03-14-2020 12:52 PM
Just build a concrete pedestal, is it a common practice? ------------------------------ Qingsong Shi ...
Donald Lee
03-14-2020 12:52 PM
When I was young I devised a clever foundation and got some advise from the architect that has stuck ...
1.
Steel structure
Like
Abu Ahmed
Posted 03-13-2020 10:00 AM
Options Dropdown
Hi, I am about to build a concrete footing for steel elevator but I have to excavate 1.5 m under the ground to reach the stable soil the thickness of the concrete footing is 0.5m now I am asking it is okay to let part of the steel elevator under the ground or I should build concrete columns to reach the ground level to fix the steel elevator on it???
Abu Ahmed Aff.M.ASCE
Al Jazera State
2.
RE: Steel structure
Like
Dennis Young
Posted 03-14-2020 09:17 AM
Options Dropdown
If the steel framing for the elevator is set on the footing with the top of footing below grade, and soil is to be placed around the columns from grade level to the top of the footing, the steel framing below grade can be coated with a layer of epoxy paint or bituminous coating and then a 3-inch (75 mm) minimum layer of concrete, built as a square or rectangular pier, can be cast around the steel framing. Any slab-on-grade work at the grade level can be poured up against the concrete pier.
Dennis Young P.E., M.ASCE
Owner/principle
Young Engineering, LLC
Omaha NE
3.
RE: Steel structure
Like
Stacey Morris
Options Dropdown
ETI Corporation
West Memphis AR
4.
RE: Steel structure
Like
Darin Gatti
Posted 03-14-2020 11:49 AM
Options Dropdown
As Mr Young point out, burying steel is generally not a good idea and the protection he suggested works very well. There are many variables to consider such as future access, clearances for machinery, and the steel details for the elevator. Bringing the concrete up to grade to meet the elevator steel is also a good option. The third option is to construct concrete walls around the footing to create an elevator pit the same way you would construct a basement. The choice between the three options is based on the building details, cost, and future maintenance needs. With the elevator pit or concrete to surface all of the steel is accessible for future maintenance or changes to the building. Discuss the options with the building architect or owner to see how each option fits in with the building design and budget.
Darin Gatti P.E., M.ASCE
Chief Engineer
Philadelphia PA
5.
RE: Steel structure
Like
Qingsong Shi
Posted 03-14-2020 12:52 PM
Edited by Qingsong Shi 03-14-2020 02:28 PM
Options Dropdown
Qingsong Shi Ph.D., P.E., M.ASCE
Senior Structural Engineer
Richtech International Eng Inc.
Katy TX
6.
RE: Steel structure
Like
Donald Lee
Options Dropdown
When I was young I devised a clever foundation and got some advise from the architect that has stuck with me. "Dig big hole, pour concrete in it" The labor to build the piers is probably more then the cost of pouring another meter of concrete in the hole. Burying steel in the ground is never a good idea. If labor is cheap and material very expensive, your solution may be viable. I would consider using a grid of intersecting walls to form the column supports. This would provide much simpler rebar detailing over piers.
Donald Lee M.ASCE
Struct Engr
Don Lee Engineering
Lakewood CA
New Best Answer
This thread already has a best answer. Would you like to mark this message as the new best answer?
Related Content
Cantilevered column system: concrete columns connecting wood-framed building to deep foundation
Edward Tornberg
Added 01-03-2026
Discussion Thread
4
Structural Stainless Steel - Moment Frame and Braced Frame Applications - Seismic Force Resisting Systems
Joseph Laquian
Added 01-30-2020
Discussion Thread
6
Mass concrete
Lee Keun
Added 05-30-2017
Discussion Thread
7
Edward Tornberg
Added 01-02-2026
Library Entry
Rehabililtaion of Concrete Structure
Ashish Ganesh
Added 09-25-2017
Discussion Thread
14
Copyright 2026. All rights reserved.
Community Tags
Add a tag
x
User Tags may not contain the following characters: @ # $ & :
