Mahmoud,
Is there something in ASCE 7 that drives the requirement to scale at top of podium? My interpretation is that scaling is intended to be at the base of the structure, not intermediate levels. I do feel that the mass of a podium can contribute to story shears above in real life, although the effect will be small if your podium has a very stiff lateral system per unit mass compared to the tower. It does feel disproportionate to put the entire building base shear on the 15th floor. Do you then design your podium for that same shear at every story, regardless of the seismic mass of the podium floors? Puts you in a weird place with diaphragm design too, assuming zero story shear below the podium roof.
To your first two discussion questions, basement levels are a can of worms and I understand that there are different opinions on how to handle this, but I take the base to be top of foundations, not at exterior grade. I wonder if the AHJ requirement for RSA scaling stems from an assumption that engineers are designing the tower from t/podium or t/grade up? Without knowing the specific requirements, it seems like they would be automatically satisfied if you take the base at the lowest basement and analyze the entire building in one global model.
To your third question, my gut says that the point of RSA is to use your analysis of relative story stiffness and mass to anticipate distribution of forces across the full structural height. RSA does push seismic force towards the top of your structure, just not quite to the extent of ELF. So you would get more favorable and less realistic (i.e. unconservative) results by placing the cutoff higher in the building if you also scale at that higher floor. Definitely curious to hear other perspectives though.
Anyone brave enough to make the case for designing from t/grade up when you have basement levels? I've heard of this practice but never caught a compelling explanation.
Christian Parker P.E., M.ASCE
Structural Project Engineer
Chicago IL
