@David Stierwalt
I have been asked to share the following response on behalf of the chair of the ASCE 7 Seismic Subcommittee:
Thank you for pointing out the issue of trying to determine the "tension deformation capacity, as determined in Section 14.2.4.6.7." Actually, you uncovered an erratum (which also exists in Sections 14.2.4.3.1 and 14.2.4.3.2) for the section being referenced. The actual section that was intended to be referred to is 14.2.4.4.7. You'll find the appropriate requirements to determine "tension deformation capacity" in this section. Thank you, again, for pointing this out.
DISCLAIMER: Reliance on the contents of this communication is solely and completely at your own risk; therefore, we advise you to exercise a reasonable degree of caution in your use of any information or advice contained herein. This information is provided for general informational purposes only and is not intended in any fashion to be a substitute for professional consultation. Under no circumstances does ASCE, its affiliates, officers, directors, employees, or volunteers warrant the completeness, accuracy, or relevancy of any information or advice provided herein, or its usefulness for any particular purpose. ASCE, its affiliates, officers, directors, employees, and volunteers expressly disclaim any and all responsibility for any liability, loss, or damage that you may cause or incur in reliance on any information or advice provided herein.
Tirza Austin
Manager, Online Community
American Society of Civil Engineers
1801 Alexander Bell Drive
Reston, VA 20191
