Dennis,
TLDR: There are no exceptions (that I know of) that would allow a residential building to use a reinforced concrete ordinary moment frame at a site with SDC D.
How I got there: I'll respond as best I can, but a little context as to where the building would be located would be helpful. Based on you providing a designation of SDC D, it appears you are designing a residence in the US, so local/state building codes would apply, which are usually modifications to the IRC and IBC. Since you are discussing a reinforced concrete OMF, which is not covered in the IRC, I would expect you would be designing in accordance with ASCE 7 and ACI 318. Look in ASCE 7-22 (you'll need to verify which year is adopted by the local building code), Table 12.2-1, Section C.7 (Ordinary reinforced concrete moment frames). Look at the entry under Seismic Design Category D. You will find the value is "NP", which stands for Not Permitted (footnote d). There are exceptions for certain types of framing (footnote e), but these do not exempt reinforced concrete OMF's (see 12.2.5.4). Note that reinforce concrete OMF's are only allowed for SDC B (per Table 12.2-1) or SDC A, since there are no seismic design requirements for SDC A.
If you are designing a structure in Canada, I would start by looking at Part 4 of the NBCC with provincial and local amendments. The NBCC 2020 uses Seismic Categories 1, 2, 3 and 4, which differ somewhat from the ASCE 7's SDC's. I note that it does appear that a residence of 2 stories or less, with a height of 10m or less, may be designed as a conventional construction reinforced concrete moment frame for a residence with SC4 designation, with the design in accordance with CSA A23.3. See NBCC Division B, Table 4.1.8.9.
Hope this helps.
Jeff Hubbell, P.E., S.E., P.Eng, M.ASCE
Tacoma, WA, US
Jeffrey Hubbell P.E., P.Eng, S.E., M.ASCE
President
Casper, Phillips & Associates
Tacoma WA
