1. You need your degree accredited (and translated into English) to be shown to be equivalent a US degree relevant to your field of engineering. If your degree is lacking in some areas (my colleague was short on Chemistry) you will need to do additional classes in your own time for the credits. You will also need to demonstrate proficiency in English if your degree was not taught in English;
2. This will give you permission to sit the EIT exam;
3. Which gives you permission to sit the PE exam;
4. (Different states have different durations/experience requirements for each of these stages; not all states require 4 years between, some just require 4 years in your career - you will need to provide an experience timeline, confirmation of employment from past employers, professional references)
5. Different states have different residency requirements to issue your license. NY needs a green card minimum, Connecticut has no residency requirements. Check with your favourite state for specifics;
6. California requires you to sit additional tests: local law, surveying, seismic.
7. SE is the same as above, though some states require a PE beforehand, some states don't, others don't recognise the SE as a separate license. Check with your favourite board;
Source: I went through this process coming from the UK: the NCEES did out my degree accreditation (there are other organisations), EIT was done in NJ, PE in CT, transferred by committee through NCEES Records to CA, sat and passed CA local exams.
It's a long process.
Marcin March P.E., CP, M.ASCE
San Francisco CA
Sent: 07-13-2017 04:51
Subject: How can I obtain a P.E. and/or a S.E. if I am from another country (Ecuador)?
I am a engineer with 10+ years of experience in which good experience with American MNCs. If I come to USA and work there still after passing FE exam I have to wait for 4 years to give PE exam???
Thk
Sandeep Barwal A.M.ASCE
Lead Civil/ Structural Engineer
GE Power
Noida
