You might find this section on handrails specified for the International Space Station useful:
1.02 PERFORMANCE REQUIREMENTS:
- General: In engineering railings to withstand structural loads indicated, determine allowable design working stresses of railing materials based on the following:
- Steel: 72 percent of minimum yield strength.
- Structural Performance of Railings: Provide railings capable of withstanding the effects of gravity loads and the following loads and stresses within limits and under conditions indicated:
- Handrails:
- Uniform load of 50 lbf/ ft. applied in any direction.
- Concentrated load of 200 lbf applied in any direction.
- Uniform and concentrated loads need not be assumed to act concurrently.
- Top Rails of Guards:
- Uniform load of 50 lbf/ft. applied in any direction.
- Infill of Guards:
- Concentrated load of 50 lbf. applied horizontally on an area of 1 sq. ft..
- Uniform load of 25 lbf/sq. ft. applied horizontally.
- Infill load and other loads need not be assumed to act concurrently.
C. Thermal Movements: Provide exterior railings that allow for thermal movements resulting from the following maximum change (range) in ambient and surface temperatures by preventing buckling, opening of joints, overstressing of components, failure of connections, and other detrimental effects. Base engineering calculation on surface temperatures of materials due to both solar heat gain and nighttime-sky heat loss.
Keep in mind the requirements that the ADA Guidelines make for the handrail diameter (1 3/4" is typically used) and that there be no obstructions within 3" above the rail and within 3/4" of either side. Essentially, that requires that the brackets supporting the handrails extend from below the rails. Although the IBC allows the brackets to be spaced up to 6'-0" apart, 4"-0" pacing (or less) makes for easier attachments and deflection control.
Robert Crossno P.E., M.ASCE
Civil Engineer Supervisor
Albuquerque NM
Sent: 03-17-2018 08:11
Subject: handrail bracket calculations
Hi Chad,
Following are two documents that I've found helpful for handrail design. Even though you may not find answers specific to your application, they both discuss the design philosophy and hopefully provide some guidance to those who stumble into this discussion topic.
1) Pipe Railing Systems Manual (ANSI/NAAMM AMP 521-01)
2) Technical Note: Comparison of Design Specifications for Design of Pipe and Round HSS Pedestrian Guardrail Systems (by AISC).
Very curious to see other contributions to this topic.
Cheers,
Tadas
Tadas Saudargas P.E., M.ASCE
Ambitech Engineering Corporation
Downers Grove IL
