I appreciate the feedback. I will keep shim plates and different grouting techniques in mind in the future.
We visited the site yesterday and got a good look at the handful of columns that are still exposed to view. It's much as we feared. Most of the base plates have a measurable gap with the leveling plate on two or more sides. Three columns are hovering with no contact whatsoever to the leveling plate. (We speculate that either there is some loose gravel or the rough edges of the plate holes are caught on the threads of the anchors.) In at least one case, there is also delamination of the leveling plate from the grout. The metal deck above is fastened to steel and the pour is scheduled for the end of this week. It looks like we're going to get everything documented in a report, then write the architect and owner to see where we go from here. My concerns at this point are:
- Cracking in the slab
- Noisy release under service load
- Fatigue damage due to cyclic variation of bearing length
- Impact to the grout upon release
- Secondary moment in the columns under eccentric bearing, base rotation
- Overstress in moment connections on upper floors under support settlement
What are everyone's thoughts on these and other consequences?
Christian Parker EIT, A.M.ASCE
Structural Project Engineer
Washington DC
(202)628-1600 EXT 190
