Designing the structure that supports components and cladding will be influenced by the type of cladding being attached to it.
Each type of cladding has its own requirements. Deflection is likely to be the determining factor in some elements.
I suggest finding a mentor that is in your firm to help you understand how the cladding needs to be supported, which support will take gravity and lateral loads, which should only be lateral loads and how to determine the forces and detailing of the connections to the girts and how to determine the load the girt will be transferring into the base structure.
There are going to be a multiple different checks required depending on the base structure and the members chosen as the girts. And even the detailing of how you are attaching each element to the next. At a minimum, strength, stability and deflections all need to be considered. Additionally, constructability is a big factor because the detailing can create construction issues that increase expense and jeopardize the quality of the final result.
All this to say that this is not a boilerplate design because there are too many variables.
My best advice is to separate out the problems you need to solve as much as possible. If a single connection starts to get to complicated figure out if there is a different way to detail it so that each connection is easier to design and construct.
Also, remember that a person is going to have to build your design. What you can put on paper is not always constructible.
Sarah Halsey P.E., M.ASCE
New York NY
