FOAM CONCRETE CHARACTERISTIC PROPERTIES
Basic concrete constituents of aggregates and cement have cement paste as the binding material (which is cement and water).
The cement paste as the binder of aggregates provides the binding energy requires for an homogeneous mixture, the addition of a foaming agent accordingly will reduced the chemical reaction of the cement paste, and the binding energy requirements.
Therefore, to have a significant improvement in strength, the foaming agent proportion should be reduced significantly, and also adequate concrete mix design must be implemented, using the trial mix approach in order to determine the optima foam concentration.
Olusegun Afolabi P.E., M.ASCE
University of Lagos
Lagos
234803 4248600
