Andres,
Thanks for sharing your perspective. From my vantage point in the US, I've never assumed that structural failure rates will be substantially lower in the US than the average for the rest of the world. There may be a degree of 'risk compensation' involved, where greater resources and experience result in undertaking more challenging projects. That seems to have been the case with this FIU bridge project:
- The owner was a very large university that desired an innovative signature bridge which could be built with minimal traffic impact, and the university was a leader in research on accelerated bridge construction (ABC)
- The designer was a leading bridge design firm which had designed many complex bridges and received hundreds of design awards
- The reviewing state agency was a large DOT with many complex bridges in its inventory, and the DOT performed extensive review of the design and plans
- The peer review firm and engineer also had experience with design of complex bridges (they represented themselves as prequalified to perform the review and were listed as prequalified on the DOT website, though, after the failure, the DOT indicated that they actually were not prequalified)
These apparent and actual strong qualifications in the project team, and the extent of independent review of the design and plans, surely contributed to the decision to undertake the design and construction of a bridge of this type at this location, and may have also influenced judgments about the significance of the cracking and whether the road under the bridge needed to be closed.
I was a member of the forensic team which investigated the spillway failures at Oroville Dam in California, which resulted in evacuation of about 188,000 people and a recovery cost over $1 billion. Some factors similar to the FIU project influenced the judgments and decision-making on the Oroville project, as described in the forensic report:
https://damsafety.org/sites/default/files/files/Independent%20Forensic%20Team%20Report%20Final%2001-05-18.pdf------------------------------
Irfan A. Alvi, P.E., M.ASCE
President & Chief Engineer
Alvi Associates, Inc.
Towson, Maryland
www.alviassociates.comialvi@...------------------------------
Sent: 10-31-2019 21:32
Subject: FIU Pedestrian Bridge Failure
Thank you for sharing this information. It is relevant in my home country because we did not expect this kind of disaster to happen in the US. The information shared covers issues regarding ethics, quality control, and level of compliance with design regulations.
Andres Guzman Ing., M.ASCE
Associate Professor
UNIVERSIDAD DEL NORTE
Barranquilla
