  • 1.  Column Design
    Posted 02-23-2019 08:27 AM
    Edited by Tirza Austin 02-23-2019 08:27 AM
    Which section of the steel could yield the maximum compression strength in a column and make a column which could resist the maximum axial compression also it may be of any shape?
    Ashwin Rajesh S.M.ASCE
  • 2.  RE: Column Design
    Posted 02-24-2019 09:40 AM
    Edited by Tirza Austin 02-24-2019 09:40 AM
    Achwin,
    In general, you need to design a column to resist all of the loads imposed on the column.  Pipe and tube columns are generally the strongest to resist compressive axial loads and resist moments in the x and y axis, however, beam connections are difficult to frame into the columns and corrosion can be a potential problem.  Compact wide flange beams are the best H shape beams for axial loading and are easy to frame beams into the webs or flanges of the column, however, they are not as good as pipe or tube columns for compressive loading.  Pipe, Tubular, and H shaped columns are normally the shapes used for columns in buildings and other structures.  Angles, channels, and tees are used as columns for stair platforms, supporting horizontal and vertical vessels, and tall towers for flares and communications.  The best shape for a column is determined by what the column is used for.
    Kenneth Clark
    Oklahoma City OK
    (405) 416-8187
  • 3.  RE: Column Design
    Posted 02-26-2019 10:59 AM
    Edited by Tirza Austin 02-26-2019 10:58 AM
    The column in used "fabricate a cold formed steel."
    Achwin,
    Kenneth Clark
    Oklahoma City OK
    (405) 416-8187
  • 4.  RE: Column Design
    Posted 02-26-2019 12:50 PM
    Edited by Tirza Austin 02-26-2019 12:49 PM
    Cold Formed Steel Column Sections follow AISI Standards, since they are much thinner than hot rolled steel column sections, they will tend to be controlled by "Local Buckling" .... "Web Crippling", you may also have to take into account any holes that may be spaced along the height of the column .... There are tables from SSMA Steel Framing - Steel Studs - Chicago, IL | Steel Stud Manufacturers Association (SSMA)
    Ssma remove preview
    Steel Stud Manufacturers Association (SSMA) is the unifed voice of the steel framing manufacturing industry. SSMAs Code Compliance Certification Program certifies that member manufacturers
    View this on Ssma >
    for steel studs that may be of some help .... Take a look of AISI for specific formulas ... etc.
    Pedro Munoz
    PRM Engineering, LLC
    Methuen MA
    (978)7388001
  • 5.  RE: Column Design
    Posted 02-24-2019 10:20 PM
    Edited by Tirza Austin 02-24-2019 10:20 PM
    Dear Ashwin,
    The best section for steel columns are Wide flange sections (W) (HEA or HEB in Europe). As Kenneth stated, you should look for sections with almost the same second moment or area around each axis so you will not have any preferred buckling direction (HSS are the best but they have connection issues). That is why standard shapes (S) (IPE in Europe) are not so common for columns but for beams, where you have a preferred axis (strong axis).
    Regards,
    Andres Guzman
    UNIVERSIDAD DEL NORTE
    Barranquilla
    573004284680
