You need to make a few things clear: is it a load bearing wall? If yes, what is the load per running meter? Then, what is the total height of the wall. Generally such walls are not made load bearing, they are used as fillers to provide good ventilation.
Since there are openings all over, you may not need to worry about the wind pressure.
You can easily provide vertical as well as horizontal bars to strengthen it.
If the brick size is bigger than 4.5 inches in width, the wall will have better stability.
Peter Singh M.ASCE
Managing Director
Kingdom Designers
Birganj
