Thank you! This a a great topic.
The dispute over use of a continuous top rail across the glass guards continues. Code and good engineering practice states that a top rail should be provided regardless if laminated glass is used or not. Architects might insist that they do not wish to see any top rail. Are 2 handrail brackets per panel or brackets installed between panels good practice or questionable?
Other topics of discussion that I have encountered include:
- analysis of stresses in glass supported by buttons
- differential deflection of glass to prevent pinching
- loads that could be present on glass partitions (floor to ceiling acting as fall protection or not)
- exposed edges of laminated glass prone to vandalism
- size limitations of glass, availability, thickness, weight, handling
- coping and drilling glass
Chad Morrison P.E., M.ASCE
Professional Engineer
Greenville RI
Sent: 01-31-2020 15:39
Subject: Architectural and Structural Use of Glass
Dear Arman
Thank you for your detailed explanation.
Also, since I know you as a hard-working researcher, I think that research is valuable.
I recommend to other friends in the forum to see this link provided by you.
https://youtu.be/IPL6Do8NpP0
Reza Mokarramaydenlou, Ph.D., C.Eng, P.E., S.E., M.ASCE
Structural Engineering and Seismic rehabilitation Consultant
Mokarramandpartners LLC
Sent: 01-31-2020 09:53
Hello Dr. Mokarram Aydenloo
Thank you for your reply on this topic.
Dr. Morse is one of our faculty members here at Michigan Technological University who will be talking about his expertise in Architectural and Structural use of Glass. As mentioned in the first post, we are hosting a FREE online presentation of his for all ASCE members. You can use the link to sign on Feb 27th. If you or any ASCE member have a specific question regarding this topic, we will convey that to Dr. Morse to address that during the presentation. Moreover, we will be having a Q&A at the end of the presentation. I highly encourage you and other members to watch our previous presentation on youtube with the link below:
We will be posting this presentation as well on our youtube channel.
Yours sincerely,
Arman
Arman Tatar S.M.ASCE
Research Assistant
Houghton MI
Sent: 01-30-2020 17:32
It is so interesting research, please provide further explanations for topic in the Forum.
Mokarramandpartners, LLC
