The commentary discusses this. It states that research and testing have been performed to show that flexural members terminating in a footing, slab, or beam (a T-joint) should have their hooks turned inward toward the axis of the member for the joint to be able to resist the flexure in the member forming the stem of the T. My initial guess was that this would provide better confinement. However, note that Section R18.8.5.1 states, "The requirement for the hook to project into the joint is to improve development of a diagonal compression strut across the joint. The requirement applies to beam and column bars terminated at a joint with a standard hook." That is not specifically for foundations, but it would make sense that the same thought process applies.
Daniel Hernandez P.E., S.E., M.ASCE
S-E-A
Rolling Meadows IL
